trm3650's avatar
trm3650
short in wiring
hello, newbie here. say i am working on my jayco, i keep blowing a 15 amp fuse at the convertor, it goes to the A/C unit and the furnace, and of course the wall thermostat.as soon as i put in a new fuse it pops real fast, sometimes it will work for a bit when we put a fuse in it. would anyone have any ideas on where to start
  • Stop blowing fuses and use a test light. When the light goes out you have removed the issue. Then you need to remove items systematically to identify where the problem exists. Easy to disconnect components to isolate the issue to be in the component or wire. Tracing an issue in the wire through inaccessible areas could prove difficult.
  • if you have a suburban furnace the wires have a plug in at the furnace unplug it and see if fuse still blows.
  • A/C unit is coleman mach thermostat on wall is coleman also
  • My converter only charges my batteries. From there the 12 volts are sent wherever it is needed. The fuses on my converter protect it from miswiring and/or reverse polarity from the incoming 120.volt system.
    Good Luck and stay safe.
  • Hello trm3650 and Welcome!
    Post Brand/Model of A/C Unit and Furnace and type of thermostat
    15A is MAIN DC for controls
    Typically that FUSE would feed DC directly to furnace and it then gets triggered by DC back from thermostat to start furnace FAN
    Some designs have the DC going to a control module in A/C Unit
    SO Bran/Models will be helpful
    ** I grew up in Casper
    Went to East Jr High, Dean Morgan Jr High, Natrona County High and then Kelly Walsh where I graduated (Dad was oilfield and we moved to/from/back to Casper a LOT!)
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 27, 2025
