hello, newbie here. say i am working on my jayco, i keep blowing a 15 amp fuse at the convertor, it goes to the A/C unit and the furnace, and of course the wall thermostat.as soon as i put in a new fu...
Stop blowing fuses and use a test light. When the light goes out you have removed the issue. Then you need to remove items systematically to identify where the problem exists. Easy to disconnect components to isolate the issue to be in the component or wire. Tracing an issue in the wire through inaccessible areas could prove difficult.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
