weberrv
Aug 04, 2017Explorer
beemerphile1 wrote:
The picture isn't clear but I am guessing it is mounted on non-conductive material. The ground wire was probably attached to a mounting screw but not to a terminal.
The ground wire (as I called it) is attached to the frame, which you can see at the bottom of the picture. Is that not ground?
