- KD4UPLExplorer IIYou would normally only need to fuse positive battery wire. The fuse size would be determined by the wire size. #10 needs a 30 amp fuse for instance.
A 200 watt system, depending how it's configured, could deliver up to 17 amps into a battery. I would want at least a 20 amp fuse or larger. That would require a minimum of #12 wire. - CresproExplorer
KD4UPL wrote:
Electricity doesn't know if it's in an inspected home installation or an RV. It will start a fire either way.
You need a fuse or circuit breaker between your charge controller and your battery. This will prevent fires if something in the charge controller ever shorts out.
You should also have all of your individual solar panels that are hooked in parallel fused (or breaker). I'm well aware that the vast majority of RV owners don't do this. It doesn't mean it's okay.
You need 4 fuses or breakers, one in series with each of your panels (assuming their all hooked in parallel). If your panels are in series and running to a high voltage MPPT controller that's a different story.
Any UL listed panel will have a sticker on the back that tells it's operating voltages and currents and also the maximum series fuse size.
Let's say all of your panels are rated for around 8 amps Isc. If one of them shorts out the other 3 will try to push their amperage thru the shorted panel. This would be 24 amps thru a panel designed for 8. As you can see, a fire may result. This is a code requirement for solar systems installed on buildings.
If you use an inline fuse between the controller and the battery, what size fuse? The system is 200W. Do you have a fuse on both positive and negative wires?
Thanks - 2oldmanExplorer IISo.. there you have it. The consensus is it's either a big problem or it isn't.
- KD4UPLExplorer IIElectricity doesn't know if it's in an inspected home installation or an RV. It will start a fire either way.
Let's say all of your panels are rated for around 8 amps Isc. If one of them shorts out the other 3 will try to push their amperage thru the shorted panel. This would be 24 amps thru a panel designed for 8. As you can see, a fire may result. This is a code requirement for solar systems installed on buildings. - pianotunaNomad IIIHi,
My panels are not fused nor circuit breaker protected between them and the controller. Between the battery bank they are both switched and fused. - Sully2ExplorerI would want them in mine!
- On the panel side it is not necessary as the solar will self limit the current. You can short the panel and no harm is done. Switch is nice if service is needed.
On the battery side you should have a fuse as the full capability of the battery is in play. s/b within 18" of B+ and rated 125% of controller output rating and not higher than wire ampacity. Although if the wire is short, fully visible and low risk of damage maybe it can be skipped. But again very convenient to have a service switch to disconnect. - 2oldmanExplorer IINo it isn't.
- wallynmExplorerIf you purchased the equipment and hired out the installation did they install every thing you provided for them to install. If so you got what you paid for. If they returned two breakers then you did not. We do not have breakers in our solar charging system.
- rgatijnet1Explorer IIII would think that there may be some times when you do not want the solar panels feeding power to the electrical system. In that case you could use the circuit breakers as switches.
38,782 PostsLatest Activity: Sep 18, 2026
