weberrv
Aug 04, 2017Explorer
time2roll wrote:
White is usually ground. You need to trace out the wires and discover why you have a dead short. Did you cut that wire or did you just replace the breaker? If the white wire goes to the battery positive... is there any chance you just serviced the battery and connected it backward.
The ShortStop had all three of those wires connected to it. The two I labeled hot were on the right side and the one I labeled ground was on the left. The "ground" wire goes directly to the frame. One of the "hot" wires runs to the battery. Is there any reason that would be connected to the negative terminal rather than the positive?
