time2roll
Sep 21, 2017Nomad
Adding Water
Generally, a certain amount of water loss is normal in all batteries, and it should be replaced with “pure” tap water or distilled water. In some areas around the country, tap water may contain chemicals or other impurities harmful to batteries. If water is needed, add just enough to bring the electrolyte to the proper level. Batteries should be filled only at the end of the charging cycle. Overfilling is the most common error made when watering, and it can cause tray corrosion. Because tray corrosion can cause EXTENSIVE DAMAGE to batteries and vehicles, extreme caution must be taken to avoid overfilling the batteries.
http://www.crownbattery.com/faqs
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
