cyntdon2010
Sep 21, 2017Explorer
time2roll wrote:
If the cell caps come off with a twist and pull of your fingers then you should lift the caps and check the water level.
Use distilled only. Fully charge first. Fill to 1/4" to 1/8" below the split ring that extends down into the cell. Just touching is absolute max.
If you are using a screwdriver or other tool to open the battery it is sealed. Leave it alone.
Picture of the top would help or at least a better description of the brand and model.
I disagree, with your statement."If you are using a screwdriver or other tool to open the battery it is sealed. Leave it alone".
My battery tops has a slot that you can open with a flat screw driver or a dime or quarter for each cap. my camper stays plug in year around so every 3 months I check the water level.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
