dougrainer
May 22, 2020Nomad
With Motorhomes, VERY FEW rv'ers have the tools and the Strength to replace a bad tire. Too HEAVY and too hard to break the Lug Nuts loose. SAME reason you do NOT purchase a Tire AND Wheel and put in your storage. What you do, is purchase a SPARE RUBBER tire and install in the storage. It is a LOT easier and lighter to get in and out. Since you will be having to use Road Side service, THEY will remove the bad Tire/wheel and then can MOUNT your spare rubber on the wheel and get you going. The biggest headache for an RV'er is to have a destroyed Tire and they have to order a new rubber to get you going. Having the rubber on the RV saves time and money. Once it is done then purchase another Rubber Tire at your earliest convienance. Doug
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
