AlwaysDreaming's avatar
May 22, 2020
Should I carry a spare tire?
Scene: On our first cross country tour with our 28 Ft. Class A Gas Motorhome, 50 miles outside Winslow, AZ on a hot Desert afternoon. All of a sudden, the TPMS (tire pressure monitor system) sounds off, rapid loss of pressure in the passenger rear inside tire. I immediately pull off and call for Emergency Roadside assistance. They ask for the tire size, Goodyear G670 RV 245/70R19.5. They said $600 and they have to order it, could be a week or two to get the tire.
So that’s my nightmare. I want to carry spare tire/wheel or just the tire.
Has anyone had this happen to them? Is it a common occurrence?
Are most of the flat tires a tread puncture that can be plugged and be run on for 500 miles?
Can most roadside service plug the tire.
I priced a spare tire system: Tire: $400; Wheel: $200; Roadmaster 195225 Spare Tire Carrier for Motorhomes $595; Hi/Lo Hitch $95; Lug Nuts, 1 Locking.
Grand Total: $1300.
Does anyone have a cheaper solution?
Does anyone carry just a tire? How do you carry it on the Motorhome?
Thanks, Al
  • Another think to consider is whether or not you'll have cellular service when you need a tire changed. It's an easier decision with a Class C and much lighter tires.
  • Bobbo's avatar
    Bobbo
    Explorer III
    I never go more than 10 miles from home without a spare tire for the vehicle and any trailer. Back a couple of decades ago, I was driving from Memphis to Atlanta to deposit a daughter at Georgia Tech, with my 6' utility trailer loaded down. Before leaving Memphis, I went to a local tire store and bought a used rim and tire for a trailer spare. I didn't have to use it, but it is still attached to the front of the trailer. (But with another tire, as I feel 20 years old is too old for a spare.)
    As long as you have it, roadside assistance can mount it and get you back on the road.
  • Can you change it yourself? OK since you are calling service anyway just have them bring a tire and pop it on the existing wheel.
  • Roadside assistance will put your tire on your rim but it might cost you a couple bucks.
    I do not carry a spare, 22.5 tires are big and heavy.
  • Having been in a somewhat similar situation, I would at least carry the tire if you have the space to put it. Road service can always mount it for you. I got taken really bad for a tire, like almost 2 times the price, when I had a problem. Won't be without one again.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
