BFL13
Nov 22, 2014Explorer II
"Equalizing" with the PD is actually just giving it a shot of 14.4 every so often when on its 13.2v Float to prevent stratification. It is not what is usually meant by "equalizing" (high voltage 15+)
14.4v is not slightly different from 14.8v-- it is vastly different.
To meet your Trojan specs you will need a different charger from the converter. EG, I use a VEC1093DBD for recharging at 14.8v and then go to the converter for the Float when that's done.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
