pianotuna
Nov 23, 2014Nomad III
Hi,
Solar is under $2 per watt especially if you DIY. You need only about 350 watts maximum. It is a one time cost. The bare minimum for equalization would be about 140 watts.
I have seen panels as low as 30 cents per watt.
If I take it easy on my inverter use, I run out of water before I run out of power.
If you want the cheapest solution, then add a battery charger capable of 14.8 volts. Be sure the generator outputs clean pure sine wave.
If you want the "nearest thing to a free lunch" solution, then go solar. It would cost me about three to four tanks of fuel for my class C.
liketoride2 wrote:
We spend a lot of time off the grid, I would estimate approximately 50%, using a generator. Solar may be in our future but I can't afford it at this time.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
