Bend
Nov 24, 2014Explorer
jrnymn7 wrote:
AH64ID,
I have no idea how the Trimetric does it, but it does seem to keep track. BFL has mentioned it adjusts for about 4% loss, so maybe it allows for too much early on, and then not enough during the later stages, but overall, it all works out?
The Tri 2025RV option P10 "Assumed charging efficiency factor" has an adjustable range of 60-100, the default is 94%. If the default does not correlate to a hydrometer showing full for your system and conditions, change the factor. I generally use 92% to understate the charge.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
