BFL13
Nov 25, 2014Explorer II
Norcold fridge spec is 15.4v limit
If VEC1093DBD are all out of stock yet again, they may find some more or not, same as previous times they have run out lately.
Another approach is the PowerMax adjustable voltage chargers that can be used as portables with cut off jumper cables and clamps or be wired in as a deck mount converter. That would solve the problem of the VEC being only 40a
I would prefer the 75a over the 60a because a pair of 6s can take the 75a ok and AFAIK--confirm with Randy!!! It might not be in this version--that unit is power factor corrected, so its VA draw on the generator is about the same as the 60's AFAIK. 15 more amps for nearly the same price as the 60 too. Scroll down to BPCMs
http://www.bestconverter.com/Powermax-Boondocker-Converters-_c_154.html
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
