BFL13
Nov 25, 2014Explorer II
Bend wrote:
I assume these BPCMs don't stage to lower volts during a charging (no manual found). Therefore, they must either be attended or put on a timer. Correct?
Yes, you set a voltage and it stays there until you change it. Good idea to use a timer to shut it off. (Mex often mentions this trick)
I can see a scenario where you have shore power and low batts and need a faster recharge overnight than your 13.6v only converter will do.
You plug in and run on converter and also charge with the BPCM and a four hour timer. While you are asleep, the timer shuts off the BPCM leaving you sitting at 13.6 on converter.
Or the timer could stop the charger after a time doing Equalize, so you don't have to be there to shut it down.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
