MEXICOWANDERER
Nov 25, 2014Explorer
Smirking...
120 amps charging rate, dial-a-yield voltage control, defaults to 13.4 volts 2-amps capacity float. Six hour timer. Adjustable equalization current, 16.0 volts regulated, also on a timer.
It's not a converter. Converters are for power pedestals. This critter is for primary use with a larger generator.
It brings the group 31 up to 14.4 volts instantaneously. Then I monitor amperage, but the six-hour timer does it all.
No thermistors
No thermistors
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
