jrnymn7
Nov 27, 2014Explorer
But yes, like BFL said, do plan for the future. You may very well need to go with four 6's, especially if you plan to use things like a microwave. You can go with a 75 amper now, for a future C/6 charge rate on a 460Ah bank, or add another 55 amper at that time, and go with two 55 ampers in parallel, for a much higher C/4 rate. Keep in mind though, you need a genset that can handle whatever you decide to go with.
FYI;
230Ah bank / 75a = C/3 rate (probably the max you should ever go)
230Ah bank / 55a = C/4 rate
460Ah bank / 75a = C/6 rate
460Ah bank / 110a = C/4 rate
FYI;
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
