pianotuna
Nov 27, 2014Nomad III
Hi
C stands for capacity. c/3 on a 90 amp-hour bank would be a charge rate of 30 amps.
At 85% of fully charged rate is about c/6 (16.6 amps per 100 amp-hours), under perfect 25 C (77 f) conditions.
Charging voltage needs to be reduced as the internal temperature of the battery rises. Charging causes an exothermic reaction in the battery. Conversely at -40 it may need to be nearly 17 volts. That means, at least for some RV products such as some fridge control boards (15.4 max voltage), that two battery banks would be best. One that is "in use" and one that is being charged.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
