NinerBikes
Dec 01, 2014Explorer
Glad you found something that will work for you. Now to figure out where to install it out of the elements, and close to the battery, with some 8 gauge wire and some ring terminals.
The shunt and amp meter should be part of the install package also, it makes it very easy to adjust the charging voltage of the unit and eliminates the guess work. You'll learn quickly, by how many amps are being flowed at what voltage, the state of charge on your batteries.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
