liketoride2's avatar
liketoride2
Should I Change My WFCO Converter?
Opinions have often been expressed, both on this and other RV forums, that most stock RV converters are inadequate to properly charge and maintain batteries and are often of poor quality. It is frequently suggested that they be replaced with an aftermarket converter, a Progressive Dynamics unit being very popular.
I have just purchased a new Coachmen Apex TT (haven't yet taken possession of it) that will use two Trojan T-105 batteries. It comes with a WFCO 8955 PEC B 55 watt converter, a 3 mode converter with outputs of 14.4, 13.6, and 13.2 volts. A PD 9260 60 watt converter has exactly the same outputs in 3 of it's modes but also has an equalizing mode with 14.4 volts every 21 hr. for 15 minutes. I found no mention of an equalizing mode on the WFCO website.
Trojan's website lists recommended charge voltages of 14.8 in absorption mode (slightly different that either converter), 13.2 in flat mode, and 15.5 (more than PD's 14.4) for equalizing. Regarding equalizing they state:
"Many experts recommend that batteries be equalized periodically, ranging anywhere from once a month to once or twice per year. However, Trojan only recommends equalizing when low or wide ranging specific gravity (+/- .015) are detected after fully charging a battery." Trojan also states an equalizing charge can be done manually by unplugging a charger and plugging it back in, although I don't know if that applies to a golf cart or RV environment, or both, or to a converter as opposed to a simple charger.
Considering that info I'm wondering if an equalizing charge every 21 hours is necessary or even desirable.
Given the cost of these batteries, I would like them to last as long as possible. My question is, given the information above, is it worth the over $200 for a Progressive Dynamics, or some other aftermarket, converter. If the only advantage of the PD over the WFCO is the equalizing mode it seems that I could do a manual equalizing charge as needed per Trojan's guidelines and the WFCO would then serve equally well. Or, are there also issues with WFCO quality that I should take into account, or any other aftermarket converters worth considering?
Thanks very much for any opinions and info that will help in this decision.
Mike
  • RoyB's avatar
    RoyB
    Explorer II
    If you have ever seen your WFCO actually go into SMART MODE charging then keep it. Most of us have never seen a WFCO Converter go into smart mode charging. I changed my 2008 model out for the PD9260C smart mode converter right away and never looked back... Maybe the newer ones are better now...
    I still use the WFCO Power Distribution Panel where all of the circuit breakers and 12VDC fuses are located.
    Roy Ken
