flownaksala
Apr 20, 2018Explorer
I'm definitely a BIG believer in Eternabond. I had some leaking coming through the roof at the seams on my 10 year old RV. I simply used the cleaner that is recommended to prep the areas and then applied the Eternabond tape. The entire job only took me about 2 hours to go around the entire roof on a 30 ft RV. It solved the problem immediately and 2 years later I have absolutely no leaks. I would recommend getting the widest Eternabond tape. I think the one I use is about 5 or 6 inches wide. I also highly recommend keeping track of all your repairs and maintenance using an excellent program called Automotive Wolf car care software. It lets you keep a detailed vehicle maintenance log. I also this program to manage my generator maintenance on my RV so that I remember to exercise the generator at least once a month to avoid problems.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
