adayjk
Aug 27, 2013Explorer
There is a fill bleed that passes liquid at the 3/4 mark on the tank. It is a little plastic thing. If it isn't tight or failed to seal it will leak. Check it, use soapy water and watch for bubbles if needed.
Did you wear gloves when you attached that fittting? If there is a sudden leak of liquid propane whan attaching thre fitting it can lead to severe frost bite, skin damage, and tissue damage. Wear the thick rubber gloves in the fill house even if the LP guy doesn't if you attach your own fill hose.
If the tank is truly overfilled it will continue to vent with temp changes until it is not.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
