dougrainer
Aug 27, 2013Nomad
westend wrote:
Be very careful. I would disconnect the tank if it's currently connected to your rig. Place the tank in the closest open area around your location. It would be good if that area is secure and you can monitor who passes by, hopefully no one.
Here's the deal: there is an overfill release valve on every tank, even the old ones. If the emergency pressure relief valve fully opens, there may be a big, sudden release of both gaseous and liquid propane. Call whoever filled the tank and have them deal with it.
I had a 20lb cylinder that was overfilled inside my work van. When the relief valve released, I couldn't see my hands on the wheel. Luckily, I was able to turn the key off and glide to a stop onto the shoulder of the road while holding my breath and looking out of the open driver's side window.
Not to get too worried, though. If the tank is in an open area where the propane can't accumulate, all will be good. As someone mentioned, wear gloves. FWIW, I have a Federal License to handle LPG and in my seafaring days we used to cool our beer by placing it under a 3/4" pipe fitting and releasing enough propane to form an iceberg over the beer cases. In 5 minutes the beer was cold and the propane ice was gone.
EXPLAIN this so called Federal License to "Handle LP". I AM licensed by the State Of Texas to work on and Fill LP appliances and systems. In the 30 years I have been licensed and the education training every 3 to 4 years, I have NEVER heard of a FEDERAL LP license OTHER than to transport BULK (semi tanker type). There is NO Federal License I am aware of that encompasses RV and such type LP systems. Your last beer statement, shows you have a severe lack of safety when it comes to LP, as the ONLY way you could do that is to release Liquid instead of vapor and that is a very dangerous thing to do in ANY circumstance. Doug
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
