ADAD437
Aug 29, 2013Explorer
flash.flood wrote:6dot6 wrote:
I guess maybe the newer models are coming with both gas and electric? This is my first camper and i have both but by your reaction thats not the case. Can you attatch a small propane tank to it?
Great minds think alike. I was driving around in my dually today trying to find a place that can make me a custom a/c line for the motor home because the condenser blew a hole and has been discontinued. The only option is a newer unit but the upper hose won't connect do to the angle. That got me thinking about bringing a small tank from our grill and just attach it to the line since I have to remove the old tank anyway. A replacement tank is $500. I wonder if the existing tank can be welded. I could fill it with water and flush it out really good. Welding a tank like that makes me nervous but what do you think? It's just one small spot on the existing weld.
btw. Impressive numbers from your dually. I have an 07 Classic and am thinking about trying to get a little more out of it. Not twins but maybe a tune and exhaust.
when i am in one place for an extended time i have the extend a stay hose set-up and two 30# tanks i use and shut off the main tank. You might want to look into this. i use it so i don't have to move the rv for propane.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
