Groover
Dec 08, 2021Explorer II
theoldwizard1 wrote:
First, if you plan on running an A/C or a residential refrigerator from an inverter, get a pure sine wave inverter.
Second, install a Micro-Air EasyStart on the A/C.
Third, if you are buying an inverter/charger get one with a builtin automatic transfer switch. Yes, it will mean some rewiring, but once installed it will be so much easier to deal with. No On/Off controls. Everything is automatic !
The coach came with a residential refrigerator, I didn't mention it because it runs fine on the old inverter. Currently only the microwave complains. I already have an easy start on the front AC and that is all that I would even think about running without the generator running.
The 3012 has a built in automatic transfer switch but the coach already has an external built in switch upstream. I don't know if I will mess with rewiring that or not.
