3_tons
Dec 11, 2021Explorer III
Regardless of inverter’s settings, Qualifying generator power (honda 2200i) while in eco mode was pretty much a no-go for my pass-thru Pro-sine 2.0 (non-hybrid) inverter, and caused me so much consternation that I ended up simply bypassing inverter output by adding another corded ATS switch just ahead of the air conditioner… New ATS defaults to generator (this corded ATS for ‘eco-mode’ only), otherwise 11kbtu air conditioner (with soft-start) will run without a hitch supplied by pass-thru inverter, shore or generator (in regular generator mode)…
What’s most interesting is that when off-grid, the inverter will run everything EXCEPT the air conditioner, while simultaneously the genny (via corded ATS) gets dedicated for the air conditioner only - if it happens to run outta gas, the ATS switches to allow the inverter to seamlessly take over the air conditioner load as well as the other loads…
3 tons
3 tons
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
