murraymcleod
Jan 13, 2015Explorer
So the pulsing pump may the problem, and I should use more water so that the pump runs continuously to even out the hot/cold pressures? Or the fix would be to adjust the pressure switch so the pump comes on sooner with pressure drops? Thanks.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
