I had a sluggish shower drain so I made a small hook in a coat hanger and went down the pipe. I pulled out a big hair plug and on the second try I pulled up a piece of white rubber about 4" long. It...
Sure sounds like the guts of a HepvO trap. If it is, I hope you have access to the underside of the shower to replace it, otherwise it will be a really big deal to fix/replace it. The gray tank can have some bad smells... if you start noticing that in the bathroom, you are probably looking at replacing the trap.
