SM49ExplorerOct 08, 2020shower taps leakingIs water supposed to run out of the tap assembly where the shower hose goes on when you turn the taps off, old one did it & so does the replacement
3 RepliesReplies sorted by NewestSM49ExplorerOct 09, 2020Thank yourockylarsonExplorerOct 09, 2020Yes.Dutch_12078Explorer IIIOct 08, 2020There's a vacuum breaker at the hose attachment point that lets the hose drain after the water is shut off at the faucet(s).
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
Related ContentNautilus P1 has leaking connectionsShower leak?Leak under showerQuick connect exterior shower hose doesn't connect.Shower Leak
