I have a 2009 keystone Montana mountaineer and the shower wall is pulling away from the side of the TT. it is only in one upper corner right at the sink area. any ideas how to secure that? I have thou...
Is the shower wall being held in with plastic rivets? ( A white or colored "head" on the wall about a little smaller than a quarter?)
If so, you can get a few at Lowes or Home Depot. Drill a 1/4 inch hole, insert rivet, hit gently with a hammer to drive the "stem" in flush,and you are done. It is very easy and will look like it is "factory."
Be careful of depth when drilling. A campers wife I know drilled three holes through the shower wall then camper wall and right outside! :)
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
