kenboat
Aug 31, 2013Explorer
Pretty much the same as you had, Horsedoc.
I had emailed Shurflo, asking about this.
Said the motor chassis arms have probably collapsed, sagged, caused by extreme heat. "Like in Arizona". And that "Shurlfo is no longer in the Comfort Air business". No chassis's available.
I am in Southern Illinois, so I am guessing they have heard of this a few times.
So I took the fan blade off, ground the corner of the blades down enough to clear the interior panel. Works fine now. If it does it again, I will grind some more or replace it.
At least now I can scratch it off the to do list.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
