TenOC's avatar
TenOC
Nomad
Feb 20, 2017
SHURFLO In-Line Check Valve Not working
City water is leaking past the check valve on my surflo pump and filling up the holding tank. I added a SHURFLO In-Line Check Valve - 1/2" Barbs 340-001 to attempt to solve the problem. However, the new check valve does not "check". I did a search and the amazon reviews states that this is a common problem (38% poor reviews) with the shurflo check valve.
Amazon Review
Any suggestion on a "good" check valve?
  • It probably just sucked up a piece of debris - usually plastic from the tank. Take the head of the pump apart and rinse all the parts off under water. I've done this several times over the years to fix that problem.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
