ericsmith32's avatar
ericsmith32
Shurflo water pump leaking
My Shurflo classic has sprung a leak, I may of cleared out the antifreeze to quick. It's coming from between the very front piece which is the on/off switch. Inside is the pieces in the second pic. Anyone experience in this fix? I can get the rebuild kit but not sure if water should be even making it that far. I'm right next to PPL motorhomes in Houston if I need anything.
  • They had the front housing for 25 or the revolution for 67.. Just went with a new pump. What a worthy upgrade. Shouldn't wake the dw at night now.
  • That front housing is where freeze damage usually occurs. You can replace it (part #94-231-30) for usually under $20. All of the 2088 series demand pumps use the same housing. Unfortunately it's more profitable for RV dealers to sell you a new pump than parts, so it's a rare dealer that stocks them. You can sometimes find them in farm stores and most certainly online.
  • Gjac's avatar
    Gjac
    Explorer III
    I noticed mine started to leak after camping in freezing temps 2 years ago. When I removed it I noticed some corrosion where the parts join which said it had a very small leak over a long period of time. I took it apart and tried to clean it and relighted the bolts but it still leaked and sucked in air. I bought a new one from Amazon and while waiting for the part to come in I took it apart one more time and put some silicone adhesive at the parting plane and that worked. So now I have a backup pump. I would try the adhesive first before buying another.
  • New pump is way to go. I JUST replaced my old Pump and am amazed at how quiet the new one is
  • The classic is being phased out.......
    You can get the 4008 Revolution at PPL.....direct replacement and an upgrade (higher flow rate & pressure)
  • The more I read I just may replace the classic with a revolution. The classic is a bit noisey, still good though. Just replace and be done with it!
  • When I went to buy parts to replace my pump from freeze damage, I found Camping World didn't have the part(s) I needed, so I just bought a new pump.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
