luvztheoutdoor1's avatar
May 14, 2016
shut off inverter?
Ya' know, I almost hate to post this and proclaim my ignorance on technical issues. I have had my Jayco Class C for about 5 years now. It came with a Xantrex XM 1000 inverter. I have been leaving it on even when connected to shore power, like when I just have it sitting at home. Should I or can I keep doing this? Is it OK to turn it off when not traveling? It has a remote on/off switch. What are the drawbacks if I have it turned off or even on? I understand that is designed to operate AC outlets when not connected to an AC source. But I never thought of turning it off when connected. Am I burning it up? Thanks for listening.
  • Does the XM 1000 have passthrough? Do the outlet(s) it feeds have a switch to shore vs inverter? If on shore power or driving, I leave my inverter on. In storage, away from the house, I turn it off.
  • corvettekent wrote:
    Think of leaving the inverter on like leaving your headlights on,
    it's more like leaving your dome light on.
  • Almot's avatar
    Almot
    Explorer III
    If this is "inverter-only" - which it probably is - there is no need to idle it. I would turn it off when on shore power. Especially in a hot weather, so that it wouldn't be heating your space (and itself) uselessly. Unless you have life-supporting devices like CPAP machine. Uninterrupted TV shows, while being important :), probably don't qualify.
    When in storage, I would turn it off too, you don't run AC loads in storage.
  • If the inverter/charger has automatic battery maintaining option, that is something good to have on all the time.
    Otherwise why leave on something you are not planning to use for few weeks, or months?
    Inverters, even when turned off by switch will always draw some power from batteries.
    Hard to beat main disconnect switch, or pulling battery clamp.
  • inverter ONLY
    or
    inverter/charger combo
    the combo unit is also a battery charger
    so you would want that ON when connected to shore power
    even if it is 'Invert Only" leaving it on means NO drop out, should there be a power problem
    we full time, our (2) inverters are always on, unless the RV is in the diesel shop, with NO shore power connected
  • horizon36 wrote:
    You are not burning it up. We are full time and our Xantrex inverter is on 24/7/365 as a back up. We have had shore power go out and the inverter picks up the load. So, if we are watching TV, the show goes on. We don't have to reboot computers, satellite receivers, reset clocks etc.
    X2
  • Think of leaving the inverter on like leaving your headlights on, it would not hurt your headlights to stay on but it will draw power from your batteries. Now if you have a transfer switch and you need back up then leave it on. I shut mine off when not in use.
  • You are not burning it up. We are full time and our Xantrex inverter is on 24/7/365 as a back up. We have had shore power go out and the inverter picks up the load. So, if we are watching TV, the show goes on. We don't have to reboot computers, satellite receivers, reset clocks etc.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
