Gdetrailer
Aug 13, 2022Explorer III
Rick Jay wrote:
Hi Chris,
Definitely check it with a magnet.
Here's the link to Pot Metal from Wikipedia. Basically it's an alloy of various metals which have a low melting point (cheaper to melt at lower temp, and not much strenght) which allows manufacturers to make an inexpensive casting of an object. It usually has little, if any, iron in the mix as that would raise the melting point, which requires more energy to melt, and thus more expensive to produce. The driving force behind pot metal is CHEAP! :)
In the link above, an important line is this: "Depending on the exact metals "thrown into the pot," pot metal can become unstable over time, as it has a tendency to bend, distort, crack, shatter, and pit with age. The low boiling point of zinc and fast cooling of newly cast parts often trap air bubbles within the cast part, weakening it." So this kind of makes it a "ticking time-bomb", so to speak.
The replacement parts, and I assume the new Tri-Mark locks, use steel for the part which provides considerably more strength and is more ductile and less brittle, so it's very unlikely to crack. And steel, with its high iron content, is magnetic. Hence why a magnet test will easily show which type of metal yours if made from.
Hope this helps.
~Rick
Don't need to "magnet test" pot metal.
Bare Pot metal has a completely different look in color and texture when compared to bare steel. Looks a lot like Galvanized coated metals (Zinc is the main ingredient in the galvanizing process).
Pot metal does not need painted either, steel needs painted or oiled if you don't want it to rust unless it is stainless steel. But you can paint pot metal but you can typically tell that the painted item is pot metal since it will be molded.
Not to mention magnets do not stick to aluminum and aluminum alloys and most varieties of stainless.
I could tell from the pictures that the entire lock body (including the door handle pull), the latch bolt and other small parts are nothing more than pot metal. The only steel there is the rod and any springs.
Much of your every day items are made up of pot metal if it has been molded.
