Coachmen63's avatar
Coachmen63
SIGMA LR-20985 ELECTRIC STEP SWITCH
We have a 2006 Coachmen Aurora Class A Motor Home and the rocker switch for the electric steps needs replaced. This switch controls whether the steps close with the screen door or stays out. The switch is from Sigma in Elkhart, IN. Switch is a black rocker switch with two blade connectors out the back. Switch number is LR-20985, 16A - 125V, 12A-250VAC, 3/4HP, 125-250V, 10A, 14V(1). I find this switch number in many different configurations, but not the one I need. Opening size is 1/2" x 1-1/8". I sent an email to Forest River to see if they know where I can find this switch or one from a different vendor.
Thanks for any help you can provide.
  • I found a black non-illuminated switch at JR Products. Item #13405.
    All of the specs match the info that is on the Sigma switch. Ended up ordering it from Amazon Prime for $7.75(not sure that is exact price, but close). Switch at JR Products is $2.00+, but it cost you almost $8.00 for ground shipment.
    Thanks for everyone's responses.
  • Look at switch 13655
    It may be good to have illuminated switch. Then you know what position it is in. Mine illuminates when switch is off.
  • I was looking at switches from JR Products and they have one that is numbered 12555, but it is illuminated (3 pins). Same size, Amps and Voltage correct. I'm thinking this may be OK for me to use except it most likely will not illuminate, which doesn't matter to me. Just trying to get a good switch.
  • The switch is not momentary. One direction causes the steps to close when the screen door closes and when flipped the other way, step stays open when screen door is closed. I believe the switch disables the proximity switch at the bottom corner of the door.
    Per Chris' response, the switch is black and its dimension are .55" x 1.125".
    Step is a 32 Series made by Kwikee (2steps).
  • That's a common switch, the actual cutout is .55" x 1.125" .
    Every RV dealer should have boxes of them in stock.
  • When I looked up your switch number it indicates that it is a momentary switch. Is this correct? Most step on/off switches are not momentary.
    Here is non-momentary
    JR products
    If it is momentary then it must have control box to step the functions. If the switch is bad JR Products should have one. They have many local vendors in many areas.
    Make and model of step?
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
