Gene_Ginny
May 07, 2014Explorer
D.E.Bishop wrote:
I signal truckers when they are clear to change lanes after passing me by using my headlight switch. I am thinking about installing a momentary ON switch to control a double pole relay in the headlight circuit. It is hard to reach down to the headlight switch and it was not made for high usage. I have a 12vdc relay with the contacts rated at 25 amps and the momentary switches are readably available.
Can anyone think of an easier way of doing what I want?
Does your Bounder have a headlight flash function on the turn signal lever? Pulling the turn signal lever toward you turns on the high beams momentarily even when the headlight switch is off on most cars and trucks but I know nothing about motorhomes.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
