MEXICOWANDERER
Mar 22, 2015Explorer
I'm sorta worried about an 1875 watt tungsten load inrush. Theirs is on a 20-amp breaker. When the power blinks the thing loses clock time reference. Why they make AC timers without a battery clock backup is beyond me
I use a 12-volt timer for my own stuff. But that would entail using a battery. An a 30-amp rated SCR.
Mrs Reese wants hot water ready for 7-9 AM and again from 5-9 PM every day. I have a 20-amp motor-rated light swtch I'll put downstream from the timer. A motor driven irrigation timer sounds good-if re-setting the clock proves to be easy. Turn off power switch the spin the dial by hand to match dial hour of the day to a wristwatch.
Leaving the hot water on all the time adds over a hundred dollars for a 60-day billing cycle.
Timers down here are ridiculously hard to find and expensive. Like 200-dollars for a 30-amp device.
In Las Penas my gas heater is wrapped with 6" of fiberglass. Also not available here.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
