greenrvgreen's avatar
greenrvgreen
Simultaneously Draining/Charging AGMs?
I have a small bank of 3 or so 35ah AGM batts, the UPG Chinee Goodees. I have two chargers for them: a Meanwell SP-200-15 (13.4A) fo bulk charging, and a two-stage 4.5 amp charger which boosts at 13.7 V and then tapers amps to finish (constant V).
MY QUESTION: What is the safe maximum V I can set the Meanwell to when simultaneously powering an inverter at high draw (400W)? My only readout of bank V will be at the posts, so I want to know the V I should set the Meanwell to (it might be charging for hours and hours) and also the max V at the posts. Thanks!
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
