harold1946
Oct 14, 2017Explorer
Sam Spade wrote:HTElectrical wrote:
Probably 2 Costco GC2 batts again. Correct???
I have a charge wizard, but since I only slightly discharge them, the only reason to use the Wiz, is to boil of the Sulfation that I cause.
Despite the quoted opinion, I think AGMs are always a better choice unless your budget is REALLY tight.
Given the usage pattern your describe, one large 12 V "deep cycle" AGM probably can be had for about the same price as replacing the two that you presently have.
No need to add water, virtually no sulphation and no corrosive gasses escaping to corrode things nearby.
All wet cell batteries are subject to sulfating, including AGMs.
