BFL13
Nov 10, 2013Explorer II
SKSCCI wrote:
Good Evening Matt!
Thanks for the details.
Here's what I got from your discussion:
1. Buy a single 200AH battery and it will be good until it dies.
2. Buy two 100AH batteries and you will get about 150AH and they will be good until ONE of them dies. When the one dies, depending on how it dies, there is a chance that it has damaged its brother in parallel. So, instead of being able to depend on a backup battery, you may be in just as much trouble if not more so with 2 in parallel.
Some people have spoken about getting 2 6 volt batteries and using them in series for a 12 volt system. Is this situation pretty much the same as far as potential problems as 2 12v in parallel?
Thanks.
Steve.
Steve, Matt is all mixed up on this topic, so listen to the others for now. You can't go wrong with this book to bring you up to speed. Matt should read it too--the author was in the navy if that helps. :)
http://www.bestconverter.com/Books_c_67.html
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
