BFL13
Oct 08, 2020Explorer II
EDIT--I see the tech link now, so I will read that, thanks.
Thanks PT. What happens if you recharge with a 45 amp converter--over the 25 amps-- does the battery have an acceptance rate that just won't allow that and self-protects like a Wet or do you ruin it?
I had that trouble with my 100AH AGMs which said max of 27 and I beat that by using two with my 55 amper. Only way to do under 27 with one is use the portable charger at its 20 amp setting.
So on recharge you have to disconnect the converter, clamp on the portable at 20 amps, wait till amps taper so you know it will be safe to go to 45 amp converter? When do amps taper with this type of batt anyway--same as Wets and AGMs or more like Li--very far along in SOC?
What counts as full? With AGMs you need an ammeter to see when amps are down to 0.5/100AH. Do you need an AH counter and ammeter to manage these batts? If you don't have to get them full I suppose that doesn't matter except for the monthly. ( and that's when to reset the AH counter if you have one)
Do you have to float them? They give the spec floating voltage range at a temp. Do you have to use temp comp to be sure to stay in that voltage bracket?
( My scenario is one battery in the camper where I can't really get at it, no Trimetric monitor--just voltage, some solar sometimes, recharge at home--would like to just connect and use the converter (too many amps) in 3-stage automatic, and not even know the battery is there for months and months.---and usage is short times off grid where 100AH is plenty before going home and while away use the MW with the high draw every so often. --at least the SiO2 can do that part ok. )
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
