BFL13
Oct 31, 2020Explorer II
On whether an SiO2 is a Gell or an AGM:
"The "SiO2" is a lead crystal battery. I am not too clear on this, but it seems it is not a ""lead-gel", but it does have an electrolyte that might be similar. The idea it is a modified "AGM battery" comes from the separator being AGM -and improved from ordinary AGM according to this blurb:
"Lead Crystal® batteries use a new advanced type of AGM material as a separator. The AGM has much higher electrical conductivity, heat resistant and acid resistant abilities than standard AGM on the market. The crystallized electrolyte in combination with the AGM can effectively protect the plates and prevent the active material from falling off during use. The electrolyte is completely absorbed and stored in the AGM. Since the AGM is completely saturated with electrolyte then crystallized, no free liquid electrolyte will be present in the battery. The "battery can now be used in various directional positions without leaking."
Good info here!
https://www.gliderpilotshop.com/lead_crystal
Good info here!
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 18, 2026
