BFL13
Nov 09, 2020Explorer II
Another way they claim faster charging with Li and in some cases, Si is that they stay in the constant amp bulk stage to a high SOC rather than tapering from the mid-70s SOC range. That is true for Li but I didn't see that as much testing my Si. As reported, amps started to taper at 87.5 %. That is still higher than the usual 75% SOC at that charging rate.
Just how much gen time you save "depends".
Where you can save time with both Si and Li is where you can safely go down to 20% before recharging. With Wets you can do a 50-80 at the high amps zone (more like 45-75 really) so a 30% zone. You start at 50% , normally the low SOC. But here you can do approx 20-90 with Si and a 20-97 with Li at the bulk current limit of the charger, up to a 25% charging rate with Si or 50% with some Li or even 1C with some.
Say you have 200AH of bank. A 20-90 is 70% or 140AH you can do at 50 amps with Si. Takes almost 3 hours. You can't compare with 200AH of AGM doing 45-75 directly. 140AH of 30% zone means the bank would be 467AH. You would need a 120 amp charger to do it in 3 hours instead of a 50 amper, and a Honda 3000 to run it instead of a 2000.
You can "use" the 140 AH with half the battery bank looking at it that way, but then again "use" has to mean "use what?" In my case the microwave can't be used down that low because of voltage drop. Li can do much better with that, so more "usable AH" with Li compared with Si for high draws and you can recharge twice as fast with Li (0.5C vs 0.25C)
So Li wins big there, but then as Itinerant1 said, you have to compare real life set-ups for just how much battery bank, what is the max amps of the charger(s), and what is the "use" -low amp draws for a long time or high amp draws for a short time, or some of each?
IMO, most RVers won't realize much of a "faster charge" than they get now for gen run times doing 50-80s while camping. Depends how limited gen hours are whether say 30 minutes saved matters, or if you are in a hurry to get it done so you can go up to the lake for a swim.
Most of the recharge time is 80-100 SOC which you don't do now anyway, and with Si you would not do the 90-100, but could do the 80-90 a the high rate, so you do save some gen time there ("depends" how much time in minutes)
Unless you can compare an exact scenario, it is not easy to prove a "faster recharge" , but it can be faster in some scenarios for sure, especially with Li.
The dollars it costs (twice as much for Li than with Si if they save the same times in the scenario in question) to save those minutes is another "worth it" nobody else can answer except the individual doing the calculation.
EDIT--I am getting tired of counting bikes and cars and fire hydrants to get on here! :(
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
