pianotuna
May 01, 2021Nomad III
StirCrazy wrote:
why would you have to remove them? just have a shut off switch and turn them off when you leave.
Steve
Steve,
You can't recharge Li when they are cold. If it is -30, it may take HOURS of furnace run time to warm up the RV and the battery bank, even if it is in the living quarters. So it may be impossible to get the battery bank to where it is possible to recharge it, unless it is a massive bank to start with. If you roll your own--fine--but if you are buying drop in it may cost a pretty penny. The alternative is to remove the batteries to a warm environment and then return them to the RV.
I realize this is an outlier possibility--but it is the situation in which I live and RV in.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
