theoldwizard1
Feb 27, 2021Explorer II
gabemcg wrote:
I need to install a 7 way outlet in the bed of my truck for this, but I'm guessing I should pull the power lead directly from the battery?
When I park and shut the truck down, I'm guessing I need to manually disconnect the cable so the camper doesn't draw down the truck battery, or does the camper have a switch that detects when the truck is running (via voltage over 12v for example?)
Most pickups that you would put a camper on already have a 7 pin connector at the rear. The simplest solution is to tap into that harness. Pin 4 is the Auxiliary Power (+12V) wire/connection.
These are typically set up from the factory to only provide power when the engine is running.
I strongly recommend a DC-DC battery charger in the camper. It is the only way to guarantee that the camper battery will get fully recharged while you are driving.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 21, 2026
