Grey_Mountain's avatar
Sep 14, 2019
Six Volt MH battery in a tractor...
I am having to replace all four of my Interstate GC2-ECL-UTL batteries. Will one of these batteries work on a Ford tractor with a six-volt system?
GM
  • They will have fewer cranking amps than a starting battery, but ought to work in good conditions. (ie tractor starts easily)
    Question is recharging them. A starting battery gets recharged right away with its thin plates. A GC2 has thicker plates. IMO try it and do some hydrometer checking after each tractor use until you are sure the GC2 is getting recharged ok.
    GM
    Yes is the quick answer but I had better starting with an 8 volt on my 9N. I eventually converted to a 12volt using a delco alternator & homemade bracket . It's been at least 20 years since I had that beast.
  • Will it "work" ?
    Sure....if it will fit properly....
    AND if it is still healthy enough to hold a charge.
    But if that is true, why are you changing them out in the first place ??
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 02, 2025
