DrewE's avatar
DrewE
Explorer III
Mar 02, 2015
Sizing a replacement converter
I'm planning on upgrading the old (loud, single-stage) converter in my '98 Coachmen class C to a PD 9200 series unit, and am trying to figure out what size to get. I'll probably be doing a little boondocking from time to time, mostly overnights rather than extended stays, so within reason faster charging would be a positive.
The current house battery is a single 12V battery of uncertain provenance and capacity. I'm thinking I'll be replacing it with a pair of golf cart batteries which I think will fit in the tray, though I haven't yet pulled out the tape measure to verify. (It's inconveniently cold in Vermont to be mucking about with such things.)
Is there any operational difficulty in having a multistage charger that's "too large" for the battery? Intuitively, I would not expect problems, since as I understand it they're basically acting as current-limited constant voltage supplies (albeit with various voltages for the various stages). The charge rate should therefore just be limited to what the battery will accept, correct?
The obvious drawbacks are a higher initial cost for the converter and possibly for larger wiring to for the increased current capacity. I won't be limited by generator capacity.
Currently, I'm leaning towards the 9270 (70A) model. The difference in cost between the 45A, 60A, and 70A models is comparatively nominal. Jumping up to higher capacities is more costly, and would also entail upgrading the AC circuit the converter is on (it's a 15A circuit presently) so I very likely won't go higher.
Thoughts? Suggestions?
