SCVJeff
Dec 31, 2015Explorer
donn0128 wrote:They are around $50 on eBay, but I question if I have a problem at all since none of the three transponders on 110 are on the air. What I also don't know is if the Traveller looks only at carrier on one of the assigned transponders or it's looking at the beacon carrier. If the latter is true, then yes, I need to replace the LNB. But short of spending the $$$ I'd first be curious is anyone elses's 3005 is failing the 110 search?
New LNBs are fairly cheap, so its probably worth replacing it as a test. If you have a meter you should be anle to check for continuity.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
