YC_1
Jan 01, 2016Nomad
There is an asterisk next to all three of mine at this time. I also check the signal strength on the tv and it is over 95 here in Central Florida.
While traveling the North East I found that 119 would often not work. I guess that bird was just a bit too low for the tall trees. Losing 110 is possible if you are parked in front of palm trees. I found this out. Moved a foot and it came alive. You said nothing has changed so if that is the case what other parts do you have between the dish and the tv? I understand you are a tech and since I am a tech I know that sometimes one gets the palm to the head when bantying things about.
In the last few days I added a SWM kit to my 4 output Travler. This device required all four of the outputs to be fed into it. I'm guessing it just fires up each lnb and sends those down one wire.
If you are not getting any signal on your tv I highly suspect the lnb. Or in my case with four wires, perhaps a connector is loose and not letting power get to the head of the dish. If you have multiple cables that is where I would start.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
