CA_Traveler
Jan 01, 2016Explorer III
fpresto wrote:If you read the posts his dish does lock in and that is not his concern. Also if you do get 110 in Maryland it may/may not be available in his California location.
The problem that the OP has is that his 3005 uses the 101, 110 and 119 to lock the dish. The 3005 is inline before the receiver so DIRECTV can do nothing because without the 110 his never locks so the receiver never gets a signal. All he needs is for someone that has a 3005 to see if there system will lock on without the 110 or if it is just his unit having problem. I would fire mine up except that mine is under cover for the Winter.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
